Philco Tropic 46-888 E.Z. Restoration
It seems strange to me that your radio is performing less than optimally, Dave.
I restored my 42-788 which is very similar, and it seems to play very well indeed. As I recall, its circuitry matched the schematic. I had no problems with it once I overcame the miles and miles of rubber-covered wiring and replaced all paper and electrolytic capacitors and many of its resistors as well. I understand that you did the same with your set's caps...so I have nothing more to offer at this point...
Philco Tropic 46-888 E.Z. Restoration - by davemc - 06-12-2016, 12:21 PM
RE: Philco Tropic 46-888 E.Z. Restoration - by Ron Ramirez - 07-20-2016, 11:29 AM
Restoring Philco 96
There are currently 7828 online users. [Complete List]
» 2 Member(s) | 7826 Guest(s)
