Speaker Wire Replacement? Model 70
Hello:
I'm considering replacing a section of the three wire bundle from the speaker plug to midway in the line to the speaker. A fair amount of insulation has cracked here and there. I'm considering shrink tubing, but that might not fit in the bakelite plug opening. Would cloth covered reproduction electric light wire work okay. Probably would work. It would look pretty good.
Dave
Speaker Wire Replacement? Model 70 - by Sourbone - 07-20-2016, 12:35 PM
RE: Speaker Wire Replacement? Model 70 - by morzh - 07-20-2016, 04:36 PM
RE: Speaker Wire Replacement? Model 70 - by morzh - 07-31-2016, 11:36 AM
Restoring Philco 96
There are currently 7492 online users. [Complete List]
» 2 Member(s) | 7490 Guest(s)
