Speaker Wire Replacement? Model 70
Hi Dave,
I've had good luck with reproduction automotive wire from Rhode Island wire:
http://philcoradio.com/phorum/showthread.php?tid=12753
If you can find reproduction electric light wire that has the right appearance that would be preferable since it would be rated by the manufacturer for a higher voltage.
Speaker Wire Replacement? Model 70 - by Sourbone - 07-20-2016, 12:35 PM
RE: Speaker Wire Replacement? Model 70 - by Nathan Slingerland - 07-20-2016, 01:30 PM
RE: Speaker Wire Replacement? Model 70 - by morzh - 07-20-2016, 04:36 PM
RE: Speaker Wire Replacement? Model 70 - by morzh - 07-31-2016, 11:36 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4394 online users. [Complete List]
» 3 Member(s) | 4391 Guest(s)
