Model 41-629 with images
Steve,
You poacher!!!!
All the station that the PB are set on are in the Philly area.
The 1st time I read your title I thought that you where getting station where they don't belong. Any way set looks to be in good shape and with rub on magic (like Sam mentioned) or Gojo/johnson paste wax would make a big improvement. As for FM perhas the simplest would be to add a switch to the phono input to switch between it and a FM tuner or any audio source. I suppose the issue is it you want to go old sckool w/ a FM tuner from the '40s they tend to be not all that great. Drift can be a problem (no afc)
Model 41-629 with images - by SteveinAlaska - 07-20-2016, 01:54 AM
RE: Model 41-629 with images - by Eliot Ness - 07-20-2016, 09:23 AM
RE: Model 41-629 with images - by KCMike - 07-20-2016, 09:51 AM
RE: Model 41-629 with images - by sam - 07-20-2016, 12:02 PM
RE: Model 41-629 with images - by SteveinAlaska - 07-20-2016, 12:46 PM
RE: Model 41-629 with images - by sam - 07-20-2016, 01:35 PM
RE: Model 41-629 with images - by Radioroslyn - 07-20-2016, 01:55 PM
RE: Model 41-629 with images - by Ron Ramirez - 07-20-2016, 02:37 PM
RE: Model 41-629 with images - by w4rtc - 07-20-2016, 05:35 PM
RE: Model 41-629 with images - by Radioroslyn - 07-20-2016, 05:41 PM
RE: Model 41-629 with images - by Ron Ramirez - 07-20-2016, 08:14 PM
RE: Model 41-629 with images - by SteveinAlaska - 07-21-2016, 02:36 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
