Philco 42-PT-2 candohm
just had one in a Emerson 59 Ch--- 2 taps on it,,,read 500 ohms,,,,here it was short out to the frame of the resistor,,,didn't figure it out till ,,I took the leds off to check it,,this one was bolted to the chassis,,,Cheers
Philco 42-PT-2 candohm - by brotherfan - 07-22-2016, 09:29 PM
RE: Philco 42-PT-2 candohm - by klondike98 - 07-22-2016, 10:03 PM
RE: Philco 42-PT-2 candohm - by Radioroslyn - 07-22-2016, 10:31 PM
RE: Philco 42-PT-2 candohm - by morzh - 07-22-2016, 11:16 PM
RE: Philco 42-PT-2 candohm - by Arran - 07-22-2016, 11:56 PM
RE: Philco 42-PT-2 candohm - by klondike98 - 07-23-2016, 08:42 AM
RE: Philco 42-PT-2 candohm - by Kenneth F. Besso Jr. - 07-23-2016, 04:55 PM
RE: Philco 42-PT-2 candohm - by codefox1 - 08-06-2016, 08:57 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6321 online users. [Complete List]
» 3 Member(s) | 6318 Guest(s)
