Bakelite?
Two points here. The set was definitely made in 1950 through 1952. I believe it used 7 pin miniature equivalents of the "All american Five" tubes. These sets were in the stores when I was Icollege in 1950-52. They were nreally well made. Indeed, they would have a Telechron clock movement. GE Owned Telechron!
But, be careful about putting heating devices in the timed outlet on this set. I don't think that the clock contacts will stand up under the heavy current drawn by your coffee pot. I seem to recall that they specified a wattage limit for the outlet, somewhere on the back panel of the set.
Bakelite? - by jayoungs - 07-19-2009, 11:45 PM
Re: Bakelite? - by Doug Houston - 07-19-2009, 11:51 PM
Re: Bakelite? - by jayoungs - 07-20-2009, 12:02 AM
Re: Bakelite? - by Texasrocker - 07-20-2009, 01:11 AM
Re: Bakelite? - by Arran - 07-20-2009, 04:51 AM
Re: Bakelite? - by jayoungs - 07-20-2009, 12:31 PM
Re: Bakelite? - by philco phan - 07-21-2009, 04:18 PM
Re: Bakelite? - by Doug Houston - 07-30-2009, 10:26 PM
Re: Bakelite? - by jayoungs - 07-31-2009, 12:31 PM
Re: Bakelite? - by Guest - 03-27-2010, 10:46 AM
