51-532 Knobs
Hello, I'm new here this is my first post, need both knobs for this radio 51-532 any ideas.
Thanks
Jim
Jim
Spring Lake MI
51-532 Knobs - by Jimradio - 07-28-2016, 08:21 AM
RE: 51-532 Knobs - by klondike98 - 07-28-2016, 08:51 AM
RE: 51-532 Knobs - by Jimradio - 07-28-2016, 01:26 PM
RE: 51-532 Knobs - by Jimradio - 08-15-2016, 07:47 AM
Philco 91 Tuning Condenser
There are currently 10109 online users. [Complete List]
» 2 Member(s) | 10107 Guest(s)
