EICO 320 Signal Generator
(07-28-2016, 08:19 AM)TV MAN Wrote:  Very nice resto! I like seeing our test equipment restored as well as radios. After all, this is what helps bring our old radios back to life. I am curious about the gold thing (diode I assume) connected to your line cord. Is this replacing the old? What did you use?
Thanks to everybody for the nice comments.
The gold thing is a dropping resistor to bring the line voltage down to 115Vac from 120vac.  I'm not sure it is really needed, but I'd rather err on the safe side.  There was no resistor before.
BTW, since there pictures were taken, I've added the extra trimmer caps (which takes it from a 320 to a 322) for each coil which made the dial more accurate, but I use a frequency counter with all my signal generators.
Crist
EICO 320 Signal Generator - by Crist Rigotti - 08-25-2015, 11:57 PM
RE: EICO 320 Signal Generator - by codefox1 - 08-26-2015, 07:36 AM
RE: EICO 320 Signal Generator - by Radioroslyn - 08-28-2015, 08:02 PM
RE: EICO 320 Signal Generator - by Crist Rigotti - 08-28-2015, 10:21 PM
RE: EICO 320 Signal Generator - by Mitch - 07-27-2016, 02:11 AM
RE: EICO 320 Signal Generator - by PhilcoMike - 07-27-2016, 04:04 PM
RE: EICO 320 Signal Generator - by Joe Rossi - 07-27-2016, 08:53 PM
RE: EICO 320 Signal Generator - by TV MAN - 07-28-2016, 08:19 AM
RE: EICO 320 Signal Generator - by Crist Rigotti - 07-28-2016, 10:44 AM
RE: EICO 320 Signal Generator - by gregb - 07-28-2016, 06:03 PM
RE: EICO 320 Signal Generator - by PhilcoMike - 07-29-2016, 04:08 PM
RE: EICO 320 Signal Generator - by Crist Rigotti - 07-31-2016, 11:08 PM
RE: EICO 320 Signal Generator - by Mitch - 07-30-2016, 01:38 AM
RE: EICO 320 Signal Generator - by PhilcoMike - 08-01-2016, 03:08 PM
RE: EICO 320 Signal Generator - by Crist Rigotti - 08-02-2016, 11:09 PM
Eico 232 VTVM Schematic
There are currently 5086 online users. [Complete List]
» 1 Member(s) | 5085 Guest(s)
