RCA Victor T-55 AM radio
Ok, Here we go again.. I was replacing caps and found one cap marked .01 on schematic C15 was really a .0025 at 700 Volts. It goes from Plate of the 6SQ7 to grid of the 6F6.
C13 marked .0025 from Resistor R5 to switch was really a .001 at 1000 Volts.. Question should I change them back to values on schematic? Also do I really need 1000 volt caps. Would 630 Volt work..
[Image: http://i292.photobucket.com/albums/mm38/...v6tr87.jpg]
Skip...
RCA Victor T-55 AM radio - by vecher - 07-17-2016, 05:10 PM
RE: RCA Victor T-55 AM radio - by Radioroslyn - 07-17-2016, 06:19 PM
RE: RCA Victor T-55 AM radio - by vecher - 07-17-2016, 08:10 PM
RE: RCA Victor T-55 AM radio - by Arran - 07-18-2016, 03:25 AM
RE: RCA Victor T-55 AM radio - by vecher - 07-18-2016, 08:59 AM
RE: RCA Victor T-55 AM radio - by vecher - 07-21-2016, 10:23 AM
RE: RCA Victor T-55 AM radio - by KCMike - 07-21-2016, 11:14 AM
RE: RCA Victor T-55 AM radio - by vecher - 07-21-2016, 07:45 PM
RE: RCA Victor T-55 AM radio - by vecher - 07-24-2016, 08:00 PM
RE: RCA Victor T-55 AM radio - by klondike98 - 07-24-2016, 08:13 PM
RE: RCA Victor T-55 AM radio - by Arran - 07-26-2016, 06:53 AM
RE: RCA Victor T-55 AM radio - by vecher - 07-28-2016, 11:34 PM
RE: RCA Victor T-55 AM radio - by Steve Davis - 07-29-2016, 09:34 AM
RE: RCA Victor T-55 AM radio - by vecher - 07-29-2016, 12:12 PM
RE: RCA Victor T-55 AM radio - by vecher - 07-29-2016, 09:02 PM
RE: RCA Victor T-55 AM radio - by vecher - 07-30-2016, 05:43 PM
RE: RCA Victor T-55 AM radio - by Radioroslyn - 07-30-2016, 06:59 PM
RE: RCA Victor T-55 AM radio - by vecher - 07-30-2016, 08:48 PM
RE: RCA Victor T-55 AM radio - by Mitch - 07-31-2016, 12:35 AM
RE: RCA Victor T-55 AM radio - by vecher - 08-02-2016, 08:10 PM
RE: RCA Victor T-55 AM radio - by Radioroslyn - 08-02-2016, 08:27 PM
RE: RCA Victor T-55 AM radio - by vecher - 08-02-2016, 11:28 PM
RE: RCA Victor T-55 AM radio - by vecher - 08-03-2016, 11:39 PM
RE: RCA Victor T-55 AM radio - by vecher - 08-04-2016, 12:30 AM
RE: RCA Victor T-55 AM radio - by vecher - 08-04-2016, 01:21 PM
RE: RCA Victor T-55 AM radio - by Radioroslyn - 08-04-2016, 04:48 PM
RE: RCA Victor T-55 AM radio - by vecher - 08-04-2016, 11:47 PM
RE: RCA Victor T-55 AM radio - by Radioroslyn - 08-08-2016, 06:33 AM
RE: RCA Victor T-55 AM radio - by vecher - 08-07-2016, 10:48 PM
RE: RCA Victor T-55 AM radio - by vecher - 08-08-2016, 09:41 AM
RE: RCA Victor T-55 AM radio - by vecher - 08-08-2016, 11:20 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
