  • 2 Vote(s) - 3.5 Average
Ron's 2016 Cabinet Work Part I: Bozak E-300
#58
Productive day on the Bozaks today...
After lunch, I wrapped some wax paper around one cabinet, at the top of the grille cloth.
Having already attached the new top to the cabinet, I then drilled pilot holes into the top trim and proceeded to nail and glue them to the new top.
The result:
[Image: http://www.philcoradio.com/images/phorum/bozak_023.jpg]
[Image: http://www.philcoradio.com/images/phorum/bozak_024.jpg]
It isn't perfect, as you can tell in the second picture - a gap somehow developed in the right front corner of the trim. I filled it with some of the same wood filler I used to fill the nail holes in the trim.
Try as I might, I did not get the trim 100% level with the top. I'll just have to live with whatever imperfections I cannot correct by sanding.
I had to buy a nail set as I did not have one. This is a really nifty tool. It did a great job of countersinking the very small nails I used to attach the trim to the top.
Anyway...after I finished with one top, I repeated the process for the second top. Both have been set aside to let the glue dry thoroughly.
While I was at it, I used the same nail chucked into the Craftsman drill to drill pilot holes for the bottom trim. I know that I may have to repeat the process after that trim gets sanded, stained, and finished.
And that is the next step - sand, stain, then finish the bottom trim and the new tops.
I compared the old trim to the new lattice molding and the new molding is just very slightly smaller than the original trim. I think it is going to work out OK.
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-02-2016, 03:31 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-02-2016, 08:29 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 07-04-2016, 05:11 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-04-2016, 10:02 PM
RE: 2016 Cabinet Work: Bozak E-300 - by Arran - 07-07-2016, 04:15 AM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-08-2016, 04:56 PM
RE: 2016 Cabinet Work: Bozak E-300 - by Arran - 07-09-2016, 05:38 AM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-10-2016, 12:06 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-15-2016, 09:27 PM
RE: 2016 Cabinet Work: Bozak E-300 - by sam - 07-16-2016, 08:34 PM
RE: 2016 Cabinet Work: Bozak E-300 - by sam - 07-16-2016, 08:55 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-16-2016, 10:23 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-18-2016, 10:20 AM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-18-2016, 12:09 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-19-2016, 09:09 AM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-22-2016, 12:08 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-23-2016, 10:18 AM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-23-2016, 12:03 PM
RE: 2016 Cabinet Work: Bozak E-300 - by morzh - 07-23-2016, 01:56 PM
RE: 2016 Cabinet Work: Bozak E-300 - by w4rtc - 07-23-2016, 08:12 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-27-2016, 10:07 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-27-2016, 10:11 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-31-2016, 12:19 PM
RE: 2016 Cabinet Work: Bozak E-300 - by Ron Ramirez - 07-31-2016, 06:14 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 07-31-2016, 06:41 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 08-01-2016, 07:43 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 08-02-2016, 07:56 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 08-02-2016, 08:36 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 08-03-2016, 11:17 AM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 08-04-2016, 09:37 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 08-07-2016, 08:26 AM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 08-12-2016, 09:43 PM
RE: 2016 Cabinet Work: Bozak E-300 - by Ed Locker - 08-13-2016, 09:26 AM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 08-13-2016, 06:19 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 08-13-2016, 06:52 PM
RE: 2016 Cabinet Work: Bozak E-300 - by TV MAN - 08-23-2016, 02:11 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 08-26-2016, 12:20 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 08-27-2016, 01:03 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 08-28-2016, 09:31 AM
RE: 2016 Cabinet Work: Bozak E-300 - by sam - 08-28-2016, 05:02 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 09-01-2016, 08:02 PM
RE: 2016 Cabinet Work: Bozak E-300 - by GarySP - 09-03-2016, 08:51 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 09-05-2016, 12:56 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 09-05-2016, 01:45 PM
RE: 2016 Cabinet Work: Bozak E-300 - by KCMike - 09-05-2016, 10:09 PM
