Philco 90 speaker qustion
You need to try 3 and 4 pins. They give 1:100 ratio which is what 20 xfmr is.
Don't go by impedance - go by ratio.
Philco 90 speaker qustion - by KCMike - 07-31-2016, 02:15 PM
RE: Philco 90 speaker qustion - by morzh - 07-31-2016, 02:34 PM
RE: Philco 90 speaker qustion - by KCMike - 07-31-2016, 04:02 PM
RE: Philco 90 speaker qustion - by morzh - 07-31-2016, 04:30 PM
RE: Philco 90 speaker qustion - by KCMike - 07-31-2016, 05:14 PM
RE: Philco 90 speaker qustion - by morzh - 07-31-2016, 07:09 PM
RE: Philco 90 speaker qustion - by KCMike - 07-31-2016, 08:30 PM
RE: Philco 90 speaker qustion - by morzh - 07-31-2016, 09:37 PM
RE: Philco 90 speaker qustion - by KCMike - 07-31-2016, 10:05 PM
RE: Philco 90 speaker qustion - by KCMike - 08-01-2016, 09:27 PM
RE: Philco 90 speaker qustion - by morzh - 08-01-2016, 09:59 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8725 online users. [Complete List]
» 3 Member(s) | 8722 Guest(s)
