MERSHON condenser rebuild
Thanks Ron, I am going to pick up a socket and try that. I had thought about drilling a hole in the aluminum and using a small bolt, but like your idea better. By the way, the inside of the electrolytic that I opened, does not have the accordion type cap, it has the spiral wound type. It was very easy to remove the inside of the roll was held onto the aluminum rod with two rivets. Michael
MERSHON condenser rebuild - by Tubesforme - 07-30-2016, 01:37 PM
RE: MERSHON condenser rebuild - by Ron Ramirez - 07-30-2016, 01:50 PM
RE: MERSHON condenser rebuild - by Tubesforme - 07-31-2016, 09:13 PM
RE: MERSHON condenser rebuild - by Tubesforme - 08-01-2016, 06:16 PM
RE: MERSHON condenser rebuild - by Phlogiston - 08-02-2016, 01:38 PM
RE: MERSHON condenser rebuild - by Tubesforme - 08-02-2016, 02:24 PM
RE: MERSHON condenser rebuild - by Tubesforme - 08-03-2016, 02:23 PM
RE: MERSHON condenser rebuild - by klondike98 - 08-01-2016, 06:37 PM
RE: MERSHON condenser rebuild - by Phlogiston - 08-02-2016, 08:29 PM
RE: MERSHON condenser rebuild - by Ron Ramirez - 08-02-2016, 10:07 PM
RE: MERSHON condenser rebuild - by Phlogiston - 08-03-2016, 09:52 AM
RE: MERSHON condenser rebuild - by Ron Ramirez - 08-03-2016, 10:31 AM
RE: MERSHON condenser rebuild - by KCMike - 08-03-2016, 10:42 AM
RE: MERSHON condenser rebuild - by Ron Ramirez - 08-03-2016, 11:02 AM
RE: MERSHON condenser rebuild - by KCMike - 08-03-2016, 11:39 AM
RE: MERSHON condenser rebuild - by morzh - 08-03-2016, 01:27 PM
RE: MERSHON condenser rebuild - by Phlogiston - 08-04-2016, 09:58 AM
RE: MERSHON condenser rebuild - by Tubesforme - 08-04-2016, 01:46 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3926 online users. [Complete List]
» 3 Member(s) | 3923 Guest(s)
