Request for opinions on model 60B restoration
Thanks for your comments. Although discouraging, I think I'm going to get some good info here. Unfortunately, if it's possible, I'm not sure how to post pictures here. Ron, I'll email them to you directly and then you can either post them here for others to see or let me know how to do it. I really appreciate your help. This guy who did my restoration has such a good reputation in the area and has done such beautiful work before, I'm having a hard time figuring out why he did what he did here....
Request for opinions on model 60B restoration - by Guest - 01-08-2006, 10:26 PM
[No subject] - by Ron Ramirez - 01-08-2006, 10:38 PM
[No subject] - by 49Stude63 - 01-08-2006, 10:42 PM
[No subject] - by Guest - 01-08-2006, 10:52 PM
[No subject] - by Ron Ramirez - 01-08-2006, 11:10 PM
[No subject] - by PTurney - 01-09-2006, 12:46 AM
[No subject] - by Ron Ramirez - 01-09-2006, 01:16 AM
[No subject] - by Guest - 01-09-2006, 07:31 AM
[No subject] - by Ron Ramirez - 01-09-2006, 11:19 AM
[No subject] - by 49Stude63 - 01-09-2006, 12:43 PM
[No subject] - by Guest - 01-09-2006, 01:10 PM
[No subject] - by Doug Houston - 01-09-2006, 03:47 PM
[No subject] - by 49Stude63 - 01-09-2006, 04:33 PM
[No subject] - by Guest - 01-10-2006, 01:19 PM
[No subject] - by PTurney - 01-10-2006, 09:10 PM
[No subject] - by Guest - 01-10-2006, 10:27 PM
There are currently 6442 online users. [Complete List]
» 2 Member(s) | 6440 Guest(s)
