Philco 39-80B
6mA.....any piece of crap el cheapo electrolytic will do. And, what's good, any capacitance. You could use 3, or 10, or even 100uF with no ill effects.
Philco 39-80B - by Radioroslyn - 08-03-2016, 09:45 PM
RE: Philco 39-80B - by morzh - 08-03-2016, 10:18 PM
RE: Philco 39-80B - by Radioroslyn - 08-03-2016, 10:34 PM
RE: Philco 39-80B - by morzh - 08-04-2016, 08:33 AM
RE: Philco 39-80B - by Radioroslyn - 08-04-2016, 02:00 PM
RE: Philco 39-80B - by KCMike - 08-04-2016, 02:27 PM
RE: Philco 39-80B - by Radioroslyn - 08-04-2016, 04:30 PM
RE: Philco 39-80B - by markmokris - 08-07-2016, 09:24 AM
RE: Philco 39-80B - by Paul Philco322 - 08-07-2016, 09:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9224 online users. [Complete List]
» 3 Member(s) | 9221 Guest(s)
