Radio Lamp
LOL.  I thought you meant a radio by Radio Lamp Co., like this:
http://www.antiqueradios.com/forums/down...?id=108270
I love radio lamps, but they just don't come up often around here.  Nice find!
Radio Lamp - by Dan Walker - 08-29-2014, 09:16 AM
RE: Radio Lamp - by Paul Philco322 - 08-29-2014, 09:16 PM
RE: Radio Lamp - by shaler78 - 08-29-2014, 09:29 PM
RE: Radio Lamp - by Dan Walker - 07-18-2016, 11:28 PM
RE: Radio Lamp - by palegreenthumb - 08-06-2016, 03:34 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
