Enormous model 62 (2 24A,s 1 27 2 71 A)
I heated my latest Philco 20 filter to 200-250 for about 45 mins until the wax at the sides was bubbly, and the stuff still wouldn't come out with a pair of needle nose. I was using a foil lined stainless serving tray from a buffet table under it. That's when I decided the next time I'll support it high enough so the mess melts and falls out on it's own. I replaced those 4 caps with plastic units that'll hopefully last longer than I do. There's plenty of oil filled motor starting capacitors out there in the 1 and 2uf range that should be just what you're looking for. I used 400v caps in the filters of my first two 20s and they seem to work okay, but I haven't measured the voltage on them with the radio on. This 20 I'm using 630v caps which are about half the size of the 400s. One thing I did to keep track of which lug is which on the filter was to unsolder R15 from lug 5 of R25 and leave the other end soldered to lug 5 on the filter. That way I could clean the tar off the filter, then add labels relative to lug 5. I replaced all resistors except R8 with 2 watt units, probably overkill but there's plenty of room for them.
Dave
Enormous model 62 (2 24A,s 1 27 2 71 A) - by Guest - 08-01-2009, 11:13 PM
Re: Enormous model 62 (2 24A,s 1 27 2 71 A) - by Guest - 08-03-2009, 05:09 PM
Re: Enormous model 62 (2 24A,s 1 27 2 71 A) - by Guest - 08-04-2009, 03:13 AM
Re: Enormous model 62 (2 24A,s 1 27 2 71 A) - by kruc - 08-04-2009, 05:56 AM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 7226 online users. [Complete List]
» 4 Member(s) | 7222 Guest(s)
AvatarAvatarAvatarAvatar
