Philco 90 arch veneer
I have learned that the arches of the Philco 90 cathedral were made with oriental wood veneer; any idea where I might be able to acquire some of this? Or what might be a suitable substitute? Thanks,
Doc
Philco 90 arch veneer - by doc612 - 08-06-2016, 03:29 PM
RE: Philco 90 arch veneer - by morzh - 08-06-2016, 05:40 PM
RE: Philco 90 arch veneer - by doc612 - 08-06-2016, 05:53 PM
RE: Philco 90 arch veneer - by Nathan Slingerland - 08-06-2016, 06:42 PM
RE: Philco 90 arch veneer - by Radioroslyn - 08-06-2016, 08:44 PM
RE: Philco 90 arch veneer - by morzh - 08-06-2016, 09:06 PM
RE: Philco 90 arch veneer - by doc612 - 08-06-2016, 09:28 PM
RE: Philco 90 arch veneer - by Steve Davis - 08-06-2016, 10:24 PM
RE: Philco 90 arch veneer - by doc612 - 08-07-2016, 05:52 PM
There are currently 9634 online users. [Complete List]
» 1 Member(s) | 9633 Guest(s)
