  • 1 Vote(s) - 4 Average
Philco 46-1201 Restoration
power resistor,,,,,but we have no schematic to tell you which one,,,I hope ,,the smarter Gentlemen will Chime in here to help you out,,,,these sometimes short out to there casing ,,it has 2 resistor readings on this one ,,,I presume,,I had one go to short ,,to the chassis bolt on,,,which it should not read ,,anything----I think
Philco 46-1201 Restoration - by vecher - 08-06-2016, 12:49 PM
RE: Philco 46-1201 Restoration - by KCMike - 08-06-2016, 12:59 PM
RE: Philco 46-1201 Restoration - by vecher - 08-06-2016, 04:44 PM
RE: Philco 46-1201 Restoration - by sam - 08-06-2016, 04:52 PM
RE: Philco 46-1201 Restoration - by Kenneth F. Besso Jr. - 08-06-2016, 04:53 PM
RE: Philco 46-1201 Restoration - by KCMike - 08-06-2016, 04:53 PM
RE: Philco 46-1201 Restoration - by vecher - 08-06-2016, 05:39 PM
RE: Philco 46-1201 Restoration - by sam - 08-06-2016, 06:31 PM
RE: Philco 46-1201 Restoration - by KCMike - 08-06-2016, 06:37 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-06-2016, 06:42 PM
RE: Philco 46-1201 Restoration - by vecher - 08-06-2016, 07:36 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 04:01 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-07-2016, 04:49 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 06:51 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 07:12 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-13-2016, 04:55 PM
RE: Philco 46-1201 Restoration - by Arran - 08-07-2016, 08:37 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 09:38 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 01:52 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 03:22 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 04:35 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 05:09 PM
RE: Philco 46-1201 Restoration - by vecher - 08-14-2016, 11:22 AM
RE: Philco 46-1201 Restoration - by vecher - 08-15-2016, 07:56 PM
RE: Philco 46-1201 Restoration - by vecher - 08-15-2016, 09:31 PM
RE: Philco 46-1201 Restoration - by vecher - 08-16-2016, 07:01 PM
RE: Philco 46-1201 Restoration - by vecher - 08-17-2016, 10:23 AM
RE: Philco 46-1201 Restoration - by vecher - 08-17-2016, 10:32 AM
RE: Philco 46-1201 Restoration - by vecher - 08-17-2016, 08:26 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-17-2016, 09:46 PM
RE: Philco 46-1201 Restoration - by vecher - 08-18-2016, 01:10 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-18-2016, 01:40 PM
RE: Philco 46-1201 Restoration - by vecher - 08-18-2016, 02:57 PM
RE: Philco 46-1201 Restoration - by vecher - 08-18-2016, 03:08 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-18-2016, 03:47 PM
RE: Philco 46-1201 Restoration - by Arran - 08-19-2016, 05:02 AM
RE: Philco 46-1201 Restoration - by vecher - 08-19-2016, 06:46 PM
RE: Philco 46-1201 Restoration - by Arran - 08-20-2016, 03:10 AM
RE: Philco 46-1201 Restoration - by vecher - 08-20-2016, 11:16 AM
RE: Philco 46-1201 Restoration - by Ron Ramirez - 08-22-2016, 07:29 AM
RE: Philco 46-1201 Restoration - by gregb - 08-22-2016, 09:13 AM
RE: Philco 46-1201 Restoration - by vecher - 08-22-2016, 10:04 AM
RE: Philco 46-1201 Restoration - by vecher - 08-22-2016, 03:44 PM
RE: Philco 46-1201 Restoration - by vecher - 09-28-2016, 10:40 PM
RE: Philco 46-1201 Restoration - by vecher - 09-28-2016, 11:45 PM
RE: Philco 46-1201 Restoration - by vecher - 09-29-2016, 11:41 PM
RE: Philco 46-1201 Restoration - by klondike98 - 09-30-2016, 07:25 AM
RE: Philco 46-1201 Restoration - by vecher - 10-02-2016, 08:59 PM
RE: Philco 46-1201 Restoration - by Arran - 10-03-2016, 04:26 AM
RE: Philco 46-1201 Restoration - by vecher - 10-03-2016, 11:00 AM
RE: Philco 46-1201 Restoration - by Arran - 10-04-2016, 03:11 AM
RE: Philco 46-1201 Restoration - by vecher - 10-04-2016, 10:17 AM
Users browsing this thread: 24 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8998 online users. [Complete List]
» 3 Member(s) | 8995 Guest(s)
