Philco 90 arch veneer
Correction- the fronts of the arches. It is definitely covered in a veneer because one of my arches is missing about half of it. In a post from 6-18 one of the posters said the veneer was "oriental wood"  so that was my clue.
Philco 90 arch veneer - by doc612 - 08-06-2016, 03:29 PM
RE: Philco 90 arch veneer - by morzh - 08-06-2016, 05:40 PM
RE: Philco 90 arch veneer - by doc612 - 08-06-2016, 05:53 PM
RE: Philco 90 arch veneer - by Nathan Slingerland - 08-06-2016, 06:42 PM
RE: Philco 90 arch veneer - by Radioroslyn - 08-06-2016, 08:44 PM
RE: Philco 90 arch veneer - by morzh - 08-06-2016, 09:06 PM
RE: Philco 90 arch veneer - by doc612 - 08-06-2016, 09:28 PM
RE: Philco 90 arch veneer - by Steve Davis - 08-06-2016, 10:24 PM
RE: Philco 90 arch veneer - by doc612 - 08-07-2016, 05:52 PM
There are currently 10699 online users. [Complete List]
» 3 Member(s) | 10696 Guest(s)
