Philco 366 problem with filter choke
Actually, I lost only 80% of the first layer (outer layer) of the winding. I will normally remove up to 2 layers of a transformer or choke looking for an open. After that, I usually give up assuming the open is on the INSIDE, or else I would have to remove too much of the coil to find it.
Philco 366 problem with filter choke - by Guest - 03-22-2009, 12:32 PM
Re: Philco 366 problem with filter choke - by Guest - 03-23-2009, 12:34 AM
Re: Philco 366 problem with filter choke - by Guest - 03-28-2009, 01:42 AM
Re: Philco 366 problem with filter choke - by davemc - 08-04-2009, 05:27 PM
