Philco 39-80B
Is it called a "farm set", because there is enough room to raise chickens in the back of that cabinet? Icon_lol
Mark K8KZ
Philco 39-80B - by Radioroslyn - 08-03-2016, 09:45 PM
RE: Philco 39-80B - by morzh - 08-03-2016, 10:18 PM
RE: Philco 39-80B - by Radioroslyn - 08-03-2016, 10:34 PM
RE: Philco 39-80B - by morzh - 08-04-2016, 08:33 AM
RE: Philco 39-80B - by Radioroslyn - 08-04-2016, 02:00 PM
RE: Philco 39-80B - by KCMike - 08-04-2016, 02:27 PM
RE: Philco 39-80B - by Radioroslyn - 08-04-2016, 04:30 PM
RE: Philco 39-80B - by markmokris - 08-07-2016, 09:24 AM
RE: Philco 39-80B - by Paul Philco322 - 08-07-2016, 09:24 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9012 online users. [Complete List]
» 3 Member(s) | 9009 Guest(s)
