  • 1 Vote(s) - 3 Average
PhrankenPhilco 610-630
Hi Mark,
Since both sets use a 42 in the audio output so your output transformer will be good there. The only thing that may be an issue is the field coil but is probably ok. Somewhere around here there's a list of models/plate impedance/field resistance. I'm sure someone can link you up.
ps ur call is expired.
de N3GTE
PhrankenPhilco 610-630 - by kc5gym - 08-07-2016, 03:40 PM
RE: PhrankenPhilco 610-630 - by Radioroslyn - 08-07-2016, 05:06 PM
RE: PhrankenPhilco 610-630 - by KCMike - 08-07-2016, 05:23 PM
RE: PhrankenPhilco 610-630 - by Radioroslyn - 08-07-2016, 05:35 PM
RE: PhrankenPhilco 610-630 - by klondike98 - 08-07-2016, 06:01 PM
RE: PhrankenPhilco 610-630 - by kc5gym - 08-07-2016, 06:37 PM
RE: PhrankenPhilco 610-630 - by kc5gym - 08-07-2016, 08:02 PM
RE: PhrankenPhilco 610-630 - by Radioroslyn - 08-07-2016, 08:51 PM
RE: PhrankenPhilco 610-630 - by kc5gym - 08-08-2016, 05:33 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5112 online users. [Complete List]
» 2 Member(s) | 5110 Guest(s)
