  • 1 Vote(s) - 3 Average
PhrankenPhilco 610-630
This is the speaker that I have.
The field coil is 693 ohms and the output transformer primary is 272 ohms.
This is for a 6F6G.
My radio has a 42 which I believe is equivalent to a 6F6.
According to the 610 schematic I should use an 1100 ohm field coil with a 500 ohm output transformer primary.
How much difference would it make to use the speaker that I have instead? Should I put a 500 ohm choke in series with the field coil?
PhrankenPhilco 610-630 - by kc5gym - 08-07-2016, 03:40 PM
RE: PhrankenPhilco 610-630 - by Radioroslyn - 08-07-2016, 05:06 PM
RE: PhrankenPhilco 610-630 - by KCMike - 08-07-2016, 05:23 PM
RE: PhrankenPhilco 610-630 - by Radioroslyn - 08-07-2016, 05:35 PM
RE: PhrankenPhilco 610-630 - by klondike98 - 08-07-2016, 06:01 PM
RE: PhrankenPhilco 610-630 - by kc5gym - 08-07-2016, 06:37 PM
RE: PhrankenPhilco 610-630 - by kc5gym - 08-07-2016, 08:02 PM
RE: PhrankenPhilco 610-630 - by Radioroslyn - 08-07-2016, 08:51 PM
RE: PhrankenPhilco 610-630 - by kc5gym - 08-08-2016, 05:33 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3672 online users. [Complete List]
» 3 Member(s) | 3669 Guest(s)
