which coil - model 52
Thank you for sharing your insights.   Now i understand.  Yes, i have continuity within the exact ohm ranges you listed. From 1 to 10, depending upon the coil.
So i believe my issue is not in the coils.  However i can still only tune to higher frequencies and best at 1 strong station, 1280 to be exact. Comes in screaming loud to the neglect of any other station.
I did replace the oscillation winding on the Osc/detector coil.  is this a symptom of winding it backwards/wrong direction?  I think i tried both directions with the same result (did this a few months ago).
Anyway it's a good radio but plays only 1 station and nothing in the lower frequencies except squeels.   I followed the alignment starting at 175kc - but the  600kc low frequency alignment, again, is not loud but perceptible.
My guess is, you know exactly where this points to but I've been struggling with it for weeks/months off/on.
which coil - model 52 - by winston763 - 08-05-2016, 12:07 AM
RE: which coil - model 52 - by morzh - 08-05-2016, 10:08 AM
RE: which coil - model 52 - by Radioroslyn - 08-05-2016, 10:46 AM
RE: which coil - model 52 - by winston763 - 08-05-2016, 01:14 PM
RE: which coil - model 52 - by morzh - 08-05-2016, 01:41 PM
RE: which coil - model 52 - by Radioroslyn - 08-05-2016, 02:37 PM
RE: which coil - model 52 - by morzh - 08-05-2016, 03:23 PM
RE: which coil - model 52 - by winston763 - 08-07-2016, 12:19 AM
RE: which coil - model 52 - by Radioroslyn - 08-07-2016, 08:25 AM
RE: which coil - model 52 - by morzh - 08-07-2016, 06:03 PM
RE: which coil - model 52 - by winston763 - 08-10-2016, 11:37 PM
RE: which coil - model 52 - by Radioroslyn - 08-11-2016, 06:13 AM
RE: which coil - model 52 - by winston763 - 08-11-2016, 11:34 PM
RE: which coil - model 52 - by Radioroslyn - 08-12-2016, 02:48 AM
RE: which coil - model 52 - by winston763 - 08-13-2016, 06:30 PM
RE: which coil - model 52 - by Radioroslyn - 08-13-2016, 07:42 PM
RE: which coil - model 52 - by winston763 - 08-18-2016, 08:40 PM
RE: which coil - model 52 - by Radioroslyn - 08-19-2016, 07:29 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5918 online users. [Complete List]
» 4 Member(s) | 5914 Guest(s)
AvatarAvatarAvatarAvatar
