42-380 escutcheon related
I have a 41-300 that was missing all of the escutcheon screw. I grabbed a sack of Hillman #490114 at Lowes. They are #2's 3/8" long. Trying to match the originals may be a bit difficult with out getting them from another set. They could use a spot of paint as they are too bright.
42-380 escutcheon related - by gfleduc - 03-03-2014, 11:23 PM
RE: 42-380 escutcheon related - by Eric T - 03-04-2014, 09:33 AM
RE: 42-380 escutcheon related - by Ron Ramirez - 03-04-2014, 11:28 AM
RE: 42-380 escutcheon related - by gfleduc - 03-06-2014, 12:07 AM
RE: 42-380 escutcheon related - by gfleduc - 03-24-2014, 12:02 PM
RE: 42-380 escutcheon related - by gfleduc - 04-26-2014, 06:05 PM
RE: 42-380 escutcheon related - by gfleduc - 04-28-2014, 10:42 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-12-2016, 01:57 PM
RE: 42-380 escutcheon related - by klondike98 - 08-12-2016, 02:39 PM
RE: 42-380 escutcheon related - by Warren - 08-15-2016, 06:39 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-16-2016, 12:59 PM
RE: 42-380 escutcheon related - by klondike98 - 08-15-2016, 02:56 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-15-2016, 08:01 PM
RE: 42-380 escutcheon related - by sam - 08-15-2016, 10:49 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-15-2016, 10:54 PM
RE: 42-380 escutcheon related - by sam - 08-16-2016, 01:07 PM
Philco 91 Tuning Condenser
There are currently 6918 online users. [Complete List]
» 2 Member(s) | 6916 Guest(s)
