42-380 escutcheon related
(08-11-2016, 10:51 PM)spiderdrummer24 Wrote:   do you just hammer in the new ones after you drill the hole?
Welcome to the Phorum!
Icon_wave
no hammer.... screws screw in  Icon_biggrin
42-380 escutcheon related - by gfleduc - 03-03-2014, 11:23 PM
RE: 42-380 escutcheon related - by Eric T - 03-04-2014, 09:33 AM
RE: 42-380 escutcheon related - by Ron Ramirez - 03-04-2014, 11:28 AM
RE: 42-380 escutcheon related - by gfleduc - 03-06-2014, 12:07 AM
RE: 42-380 escutcheon related - by gfleduc - 03-24-2014, 12:02 PM
RE: 42-380 escutcheon related - by gfleduc - 04-26-2014, 06:05 PM
RE: 42-380 escutcheon related - by gfleduc - 04-28-2014, 10:42 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-12-2016, 01:57 PM
RE: 42-380 escutcheon related - by klondike98 - 08-12-2016, 02:39 PM
RE: 42-380 escutcheon related - by Warren - 08-15-2016, 06:39 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-16-2016, 12:59 PM
RE: 42-380 escutcheon related - by klondike98 - 08-15-2016, 02:56 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-15-2016, 08:01 PM
RE: 42-380 escutcheon related - by sam - 08-15-2016, 10:49 PM
RE: 42-380 escutcheon related - by Radioroslyn - 08-15-2016, 10:54 PM
RE: 42-380 escutcheon related - by sam - 08-16-2016, 01:07 PM
Philco 91 Tuning Condenser
