Philco 70 Lowboy
So I see. Well, good for them. Icon_neutral
http://www.radiomuseum.org/r/philco_70_lowboy.html
When I get home, I'll look up the 70 and 50 lowboy cabinets again in Philco Furniture History, but I don't think that I will find anything different.
Philco 70 Lowboy - by Jayce - 08-10-2016, 09:24 PM
RE: Philco 70 Lowboy - by Ron Ramirez - 08-10-2016, 09:55 PM
RE: Philco 70 Lowboy - by morzh - 08-10-2016, 09:59 PM
RE: Philco 70 Lowboy - by Jayce - 08-10-2016, 10:24 PM
RE: Philco 70 Lowboy - by Jayce - 08-12-2016, 01:13 PM
RE: Philco 70 Lowboy - by Jayce - 08-12-2016, 03:28 PM
RE: Philco 70 Lowboy - by Radioroslyn - 08-12-2016, 04:42 PM
RE: Philco 70 Lowboy - by Jayce - 08-12-2016, 07:10 PM
RE: Philco 70 Lowboy - by Radioroslyn - 08-12-2016, 07:35 PM
RE: Philco 70 Lowboy - by Jayce - 08-12-2016, 09:47 PM
RE: Philco 70 Lowboy - by Ron Ramirez - 08-13-2016, 05:43 AM
RE: Philco 70 Lowboy - by Jayce - 08-13-2016, 07:19 AM
RE: Philco 70 Lowboy - by Ron Ramirez - 08-13-2016, 09:21 AM
RE: Philco 70 Lowboy - by Jayce - 08-13-2016, 04:52 PM
RE: Philco 70 Lowboy - by Arran - 08-14-2016, 04:32 AM
RE: Philco 70 Lowboy - by Jayce - 08-14-2016, 05:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
