Tube Pin Identification
How do I know from a schematic which pins are which on the tube socket sitting in the chassis? The heater pins are easy to identify because of continuity testing and they seem to be larger diameter but what about the others? I can't always trust tracing the circuit because the radio came to me non functioning and the circuitry doesn't appear to be correct in some instances when looking at the schematic. Is there a clock position that's always constant or something? -thanks
Tube Pin Identification - by IowaPhilco - 08-13-2016, 10:48 AM
RE: Tube Pin Identification - by klondike98 - 08-13-2016, 12:26 PM
RE: Tube Pin Identification - by David - 08-13-2016, 12:30 PM
RE: Tube Pin Identification - by Radioroslyn - 08-13-2016, 12:49 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 01:57 PM
RE: Tube Pin Identification - by Radioroslyn - 08-13-2016, 05:50 PM
RE: Tube Pin Identification - by Radioroslyn - 08-13-2016, 12:55 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 01:50 PM
RE: Tube Pin Identification - by Jim Koehler - 08-13-2016, 02:02 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 02:03 PM
RE: Tube Pin Identification - by klondike98 - 08-13-2016, 02:15 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 02:50 PM
RE: Tube Pin Identification - by Radioroslyn - 08-14-2016, 05:53 AM
RE: Tube Pin Identification - by IowaPhilco - 08-14-2016, 12:31 AM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 2740 online users. [Complete List]
» 1 Member(s) | 2739 Guest(s)
