Tube Pin Identification
Hi....
The RCA Triple Pindex is, by far, the most easiest and concise index to use for tracking down pin numbers. Take a look at it.....
https://www.amazon.com/Triple-Pindex-Rec...B002DS74PG
And here.....
https://www.google.com/search?q=RCA+Trip...BygC&dpr=1
Tube Pin Identification - by IowaPhilco - 08-13-2016, 10:48 AM
RE: Tube Pin Identification - by klondike98 - 08-13-2016, 12:26 PM
RE: Tube Pin Identification - by David - 08-13-2016, 12:30 PM
RE: Tube Pin Identification - by Radioroslyn - 08-13-2016, 12:49 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 01:57 PM
RE: Tube Pin Identification - by Radioroslyn - 08-13-2016, 05:50 PM
RE: Tube Pin Identification - by Radioroslyn - 08-13-2016, 12:55 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 01:50 PM
RE: Tube Pin Identification - by Jim Koehler - 08-13-2016, 02:02 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 02:03 PM
RE: Tube Pin Identification - by klondike98 - 08-13-2016, 02:15 PM
RE: Tube Pin Identification - by IowaPhilco - 08-13-2016, 02:50 PM
RE: Tube Pin Identification - by Radioroslyn - 08-14-2016, 05:53 AM
RE: Tube Pin Identification - by IowaPhilco - 08-14-2016, 12:31 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8499 online users. [Complete List]
» 3 Member(s) | 8496 Guest(s)
