610 Chassis Restoration
https://www.amaco.com/t/mixed-media/meta...rub-n-buff
Interesting. Sort of covering up the rust w/wax.
610 Chassis Restoration - by kc5gym - 08-14-2016, 08:53 PM
RE: 610 Chassis Restoration - by morzh - 08-14-2016, 09:00 PM
RE: 610 Chassis Restoration - by Radioroslyn - 08-14-2016, 09:39 PM
RE: 610 Chassis Restoration - by kc5gym - 08-14-2016, 09:47 PM
RE: 610 Chassis Restoration - by Paul Philco322 - 08-15-2016, 08:18 PM
RE: 610 Chassis Restoration - by kc5gym - 08-15-2016, 08:56 PM
RE: 610 Chassis Restoration - by kc5gym - 08-15-2016, 08:59 PM
RE: 610 Chassis Restoration - by Radioroslyn - 08-15-2016, 09:17 PM
RE: 610 Chassis Restoration - by kc5gym - 08-15-2016, 09:36 PM
RE: 610 Chassis Restoration - by kc5gym - 08-15-2016, 09:42 PM
RE: 610 Chassis Restoration - by Radioroslyn - 08-15-2016, 09:59 PM
RE: 610 Chassis Restoration - by kc5gym - 08-15-2016, 10:11 PM
RE: 610 Chassis Restoration - by IowaPhilco - 08-17-2016, 12:59 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7899 online users. [Complete List]
» 3 Member(s) | 7896 Guest(s)
