  • 1 Vote(s) - 5 Average
Got bored today so took my 37-690 apart
Ted
As others have said, no step by step instructions on tearing one down.  There is some info available on this Phorum and the other forum as well.  Any questions, do not hesitate to ask.  I sold that one to a club member, no worries I actually got them as a pair.  Will be going through the second one this winter.  When the 37-690 is done right, it is one of the best out there.
Take lots of pictures before and after and all will go smooth!
Got bored today so took my 37-690 apart - by Skip - 11-19-2013, 10:33 PM
RE: Got bored today so took my 37-690 apart - by Skip - 08-15-2016, 09:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3764 online users. [Complete List]
» 3 Member(s) | 3761 Guest(s)
