Model 42-854T purchase
 If the set was electrically restored, (including the rubber/gutta perch wire replaced) and is in excellent cosmetic condition (plastic escutcheon and knobs not warped to death and cracked), maybe $80 on a very good day, otherwise no.
If you run into another radio that you are thinking about buying, not necessarily a Philco, ask the phorum before laying your money down.
Model 42-854T purchase - by ttnt2 - 08-16-2016, 06:49 PM
RE: Model 42-854T purchase - by klondike98 - 08-16-2016, 10:00 PM
RE: Model 42-854T purchase - by Radioroslyn - 08-16-2016, 11:45 PM
RE: Model 42-854T purchase - by Arran - 08-17-2016, 03:26 AM
RE: Model 42-854T purchase - by Radioroslyn - 08-17-2016, 12:56 PM
RE: Model 42-854T purchase - by sam - 08-17-2016, 01:35 PM
RE: Model 42-854T purchase - by OldRestorer - 08-17-2016, 02:39 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
