Request for opinions on model 60B restoration
Brian - your 60B is the July 1934 (1935 season) style.
Request for opinions on model 60B restoration - by Guest - 01-08-2006, 10:26 PM
[No subject] - by Ron Ramirez - 01-08-2006, 10:38 PM
[No subject] - by 49Stude63 - 01-08-2006, 10:42 PM
[No subject] - by Guest - 01-08-2006, 10:52 PM
[No subject] - by Ron Ramirez - 01-08-2006, 11:10 PM
[No subject] - by PTurney - 01-09-2006, 12:46 AM
[No subject] - by Ron Ramirez - 01-09-2006, 01:16 AM
[No subject] - by Guest - 01-09-2006, 07:31 AM
[No subject] - by Ron Ramirez - 01-09-2006, 11:19 AM
[No subject] - by 49Stude63 - 01-09-2006, 12:43 PM
[No subject] - by Guest - 01-09-2006, 01:10 PM
[No subject] - by Doug Houston - 01-09-2006, 03:47 PM
[No subject] - by 49Stude63 - 01-09-2006, 04:33 PM
[No subject] - by Guest - 01-10-2006, 01:19 PM
[No subject] - by PTurney - 01-10-2006, 09:10 PM
[No subject] - by Guest - 01-10-2006, 10:27 PM
