Speaker Replacement
(08-17-2016, 08:35 PM)Greenhorn Wrote:
(08-17-2016, 05:15 PM)Radioroslyn Wrote:  Hiya Green and welcome!
Your spkr is toast sorry! Can replace it with a similar type, try an ad in the wanted section.
Or
Use a modern spkr replacing the FC with a choke or resistor. Then use a suitable matching transformer @ 7k to 8 ohms. I can go into more detail if you like.
Thanks for the reply. I would love for you to go into more detail.
Check PM box
tnx
38-93 Speaker. Newbie Warning. - by Greenhorn - 08-17-2016, 11:06 AM
RE: Speaker Replacement - by klondike98 - 09-09-2016, 11:31 AM
RE: Speaker Replacement - by Greenhorn - 09-09-2016, 12:38 PM
RE: 38-93 Speaker. Newbie Warning. - by Greenhorn - 08-17-2016, 08:35 PM
RE: 38-93 Speaker. Newbie Warning. - by Radioroslyn - 08-17-2016, 09:31 PM
RE: 38-93 Speaker. Newbie Warning. - by Greenhorn - 08-18-2016, 09:48 AM
Speaker Replacement - by Greenhorn - 09-09-2016, 11:09 AM
RE: Speaker Replacement - by Radioroslyn - 09-09-2016, 11:28 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8782 online users. [Complete List]
» 3 Member(s) | 8779 Guest(s)
