Philco 37-630 off/on, tone control
Hello Phil:
I have a suggestion and a request for assistance. First, Mark Oppat at Old Radio Parts repairs tone/volume controls. Perhaps he can repair your switch. See the following link: http://www.oldradioparts.net/controls.html
Second, I'm working on a Philco 37-620 and would like to know if it uses the same combined tone control/AC switch as your Philco 37-630. Do you have a schematic and parts list for the 37-630? (I could not locate one on the web.) The 37-620 uses a three-position switch, Part Number 42-1182.
Allen
Re: Philco 37-630 off/on, tone control - by Arran - 08-06-2009, 10:00 PM
Re: Philco 37-630 off/on, tone control - by Allen in SB - 08-09-2009, 11:41 PM
