  • 1 Vote(s) - 4 Average
Philco 46-1201 Restoration
#37
Having a hard time following along as your small piece of a schematic doesn't disclose the whole picture. Try this diagram:
http://www.rsp-italy.it/Electronics/Radi...n/1947.pdf
See pg 115. It seems to be closer to what you have.
Philco 46-1201 Restoration - by vecher - 08-06-2016, 12:49 PM
RE: Philco 46-1201 Restoration - by KCMike - 08-06-2016, 12:59 PM
RE: Philco 46-1201 Restoration - by vecher - 08-06-2016, 04:44 PM
RE: Philco 46-1201 Restoration - by sam - 08-06-2016, 04:52 PM
RE: Philco 46-1201 Restoration - by KCMike - 08-06-2016, 04:53 PM
RE: Philco 46-1201 Restoration - by vecher - 08-06-2016, 05:39 PM
RE: Philco 46-1201 Restoration - by sam - 08-06-2016, 06:31 PM
RE: Philco 46-1201 Restoration - by KCMike - 08-06-2016, 06:37 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-06-2016, 06:42 PM
RE: Philco 46-1201 Restoration - by vecher - 08-06-2016, 07:36 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 04:01 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-07-2016, 04:49 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 06:51 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 07:12 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-13-2016, 04:55 PM
RE: Philco 46-1201 Restoration - by Arran - 08-07-2016, 08:37 PM
RE: Philco 46-1201 Restoration - by vecher - 08-07-2016, 09:38 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 01:52 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 03:22 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 04:35 PM
RE: Philco 46-1201 Restoration - by vecher - 08-13-2016, 05:09 PM
RE: Philco 46-1201 Restoration - by vecher - 08-14-2016, 11:22 AM
RE: Philco 46-1201 Restoration - by vecher - 08-15-2016, 07:56 PM
RE: Philco 46-1201 Restoration - by vecher - 08-15-2016, 09:31 PM
RE: Philco 46-1201 Restoration - by vecher - 08-16-2016, 07:01 PM
RE: Philco 46-1201 Restoration - by vecher - 08-17-2016, 10:23 AM
RE: Philco 46-1201 Restoration - by vecher - 08-17-2016, 10:32 AM
RE: Philco 46-1201 Restoration - by vecher - 08-17-2016, 08:26 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-17-2016, 09:46 PM
RE: Philco 46-1201 Restoration - by vecher - 08-18-2016, 01:10 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-18-2016, 01:40 PM
RE: Philco 46-1201 Restoration - by vecher - 08-18-2016, 02:57 PM
RE: Philco 46-1201 Restoration - by vecher - 08-18-2016, 03:08 PM
RE: Philco 46-1201 Restoration - by Radioroslyn - 08-18-2016, 03:47 PM
RE: Philco 46-1201 Restoration - by Arran - 08-19-2016, 05:02 AM
RE: Philco 46-1201 Restoration - by vecher - 08-19-2016, 06:46 PM
RE: Philco 46-1201 Restoration - by Arran - 08-20-2016, 03:10 AM
RE: Philco 46-1201 Restoration - by vecher - 08-20-2016, 11:16 AM
RE: Philco 46-1201 Restoration - by Ron Ramirez - 08-22-2016, 07:29 AM
RE: Philco 46-1201 Restoration - by gregb - 08-22-2016, 09:13 AM
RE: Philco 46-1201 Restoration - by vecher - 08-22-2016, 10:04 AM
RE: Philco 46-1201 Restoration - by vecher - 08-22-2016, 03:44 PM
RE: Philco 46-1201 Restoration - by vecher - 09-28-2016, 10:40 PM
RE: Philco 46-1201 Restoration - by vecher - 09-28-2016, 11:45 PM
RE: Philco 46-1201 Restoration - by vecher - 09-29-2016, 11:41 PM
RE: Philco 46-1201 Restoration - by klondike98 - 09-30-2016, 07:25 AM
RE: Philco 46-1201 Restoration - by vecher - 10-02-2016, 08:59 PM
RE: Philco 46-1201 Restoration - by Arran - 10-03-2016, 04:26 AM
RE: Philco 46-1201 Restoration - by vecher - 10-03-2016, 11:00 AM
RE: Philco 46-1201 Restoration - by Arran - 10-04-2016, 03:11 AM
RE: Philco 46-1201 Restoration - by vecher - 10-04-2016, 10:17 AM
Users browsing this thread: 23 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8977 online users. [Complete List]
» 3 Member(s) | 8974 Guest(s)
