which coil - model 52
I agree with the voltage differences but i can't seem to bring them down(on 24) /up (on 35).
However, it seems to come back to the tickler coil i wound, as you stated.
For an experiment, I coiled a separate tube with more turns than i originally did on the tickler and connected the 2 open ends with alligator clips to the same points as the tickler.  In other words a supplemental "booster" coil.  Now i can align up and down the dial - i get 830 loud and strong along with the other stations for the first time.
HOWEVER, the alignment is a very 'compressed' band on the dial with 830 located at 1100 or so and all the stations up to 1600.
so, when i 'fixed' the actual tickler does this result point to too many "turns" as a result of this "booster" coil?  At least i know how to get the stations but ideally they'd like up better to the dial.
Sure appreciate your help !
Rich
which coil - model 52 - by winston763 - 08-05-2016, 12:07 AM
RE: which coil - model 52 - by morzh - 08-05-2016, 10:08 AM
RE: which coil - model 52 - by Radioroslyn - 08-05-2016, 10:46 AM
RE: which coil - model 52 - by winston763 - 08-05-2016, 01:14 PM
RE: which coil - model 52 - by morzh - 08-05-2016, 01:41 PM
RE: which coil - model 52 - by Radioroslyn - 08-05-2016, 02:37 PM
RE: which coil - model 52 - by morzh - 08-05-2016, 03:23 PM
RE: which coil - model 52 - by winston763 - 08-07-2016, 12:19 AM
RE: which coil - model 52 - by Radioroslyn - 08-07-2016, 08:25 AM
RE: which coil - model 52 - by morzh - 08-07-2016, 06:03 PM
RE: which coil - model 52 - by winston763 - 08-10-2016, 11:37 PM
RE: which coil - model 52 - by Radioroslyn - 08-11-2016, 06:13 AM
RE: which coil - model 52 - by winston763 - 08-11-2016, 11:34 PM
RE: which coil - model 52 - by Radioroslyn - 08-12-2016, 02:48 AM
RE: which coil - model 52 - by winston763 - 08-13-2016, 06:30 PM
RE: which coil - model 52 - by Radioroslyn - 08-13-2016, 07:42 PM
RE: which coil - model 52 - by winston763 - 08-18-2016, 08:40 PM
RE: which coil - model 52 - by Radioroslyn - 08-19-2016, 07:29 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6714 online users. [Complete List]
» 3 Member(s) | 6711 Guest(s)
