42-1015 OLD FM BAND( BOL Cabinet)
I've owned my 42-1013 since 1978. I haven't fired it up in the last 25 years, but I remember listening to FM channels up to around 98. I'm perplexed why everyone says you can't pick anything up on the prewar FM dial. I understand the reasoning why they say you can't pick anything up, but confused to why I can. I can't wait to restore my unit and start listening to it again.
42-1015 OLD FM BAND( BOL Cabinet) - by davidff - 08-19-2016, 01:26 PM
RE: 42-1015 OLD FM BAND( BOL Cabinet) - by vecher - 08-19-2016, 02:21 PM
RE: 42-1015 OLD FM BAND( BOL Cabinet) - by Kestas - 08-21-2016, 08:55 PM
RE: 42-1015 OLD FM BAND( BOL Cabinet) - by Sean - 10-28-2016, 05:18 PM
RE: 42-1015 OLD FM BAND( BOL Cabinet) - by Sean - 11-03-2016, 09:15 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6909 online users. [Complete List]
» 3 Member(s) | 6906 Guest(s)
