record changer needle arm rejecting
Can't answer your question but welcome to the Phorum!
Icon_wave
record changer needle arm rejecting - by P230477 - 08-23-2016, 04:34 PM
RE: record changer needle arm rejecting - by klondike98 - 08-23-2016, 06:42 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
