Can You Wash Photofinish???
I have used GoJo or Goop hand cleaner on cabinets with a photofinish and then wiped with a damp sponge without problems.
Can You Wash Photofinish??? - by Farm Radio - 08-25-2016, 06:25 PM
RE: Can You Wash Photofinish??? - by NostalgiaRadioTime - 08-25-2016, 07:05 PM
RE: Can You Wash Photofinish??? - by Radioroslyn - 08-25-2016, 07:08 PM
RE: Can You Wash Photofinish??? - by Warren - 08-26-2016, 01:36 PM
RE: Can You Wash Photofinish??? - by GarySP - 08-26-2016, 03:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6786 online users. [Complete List]
» 1 Member(s) | 6785 Guest(s)
