PT-33 project?
The PT-33 is a 1940 model. It came out in August 1939 as a 1940 model.
All of those tiny Transitone chassis are basically the same. I've done a few, including a 40-501 for Sam late last year. They perform well once properly restored.
I have found that the only way I can redo one of those chassis, since it is so cramped underneath, is to strip everything out, all of the old wiring, everything...and start over from scratch. YMMV.
PT-33 project? - by 37silverstreak - 08-25-2016, 09:27 PM
RE: PT-33 project? - by Ron Ramirez - 08-25-2016, 09:37 PM
RE: PT-33 project? - by Paul Philco322 - 08-25-2016, 09:41 PM
RE: PT-33 project? - by 37silverstreak - 08-25-2016, 09:48 PM
RE: PT-33 project? - by sam - 08-25-2016, 10:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
