Can You Wash Photofinish???
Hmm, it is hard to say. We had a fire and I know that soot is one of the hardest things to get cleaned off. Usually the finish comes off with it,it is baked on too. Try the gojo that was suggested. Probably your best bet.
Can You Wash Photofinish??? - by Farm Radio - 08-25-2016, 06:25 PM
RE: Can You Wash Photofinish??? - by Radioroslyn - 08-25-2016, 07:08 PM
RE: Can You Wash Photofinish??? - by Warren - 08-26-2016, 01:36 PM
RE: Can You Wash Photofinish??? - by GarySP - 08-26-2016, 03:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
