I.F. Transformer rewind help.
(08-26-2016, 03:36 PM)GarySP Wrote:  A little late now, but in the future run the point of a straightpin across the coil and count the number of "bumps" you encounter.  This will tell you how many coils are in the winding.  Then check the thickness of the wire with a micrometer to determine the gauge of enameled magnet wire you need for the re-winding.  Take care, Gary
This method works well if the winding is just one layer. Typically the coils inside an IF transformer are multi layer and would be difficult to ascertain the number of turns. Good for rf and oscillator coils if there not too low in frequency.
I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 10:50 AM
RE: I.F. Transformer rewind help. - by KCMike - 08-26-2016, 12:31 PM
RE: I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 12:53 PM
RE: I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 08:03 PM
RE: I.F. Transformer rewind help. - by GarySP - 08-26-2016, 03:36 PM
RE: I.F. Transformer rewind help. - by Radioroslyn - 08-26-2016, 04:32 PM
RE: I.F. Transformer rewind help. - by GarySP - 08-27-2016, 12:52 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6264 online users. [Complete List]
» 3 Member(s) | 6261 Guest(s)
