I.F. Transformer rewind help.
(08-26-2016, 12:53 PM)Greenhorn Wrote:  Thank You, this will be helpful. Maybe I can measure the length of the old wire then use the calculator to determine what gauge it actually is. Just guesstimating, I'd say it's at least 75'.
So I understand you like torture! Go here:
http://www.oldradioparts.com/pg20.htm   and buy a 37-60 chassis or see if Gary will pull out the IF transformer and sell it separate. Looks like his got several chassis to choose from. It has the proper frequency transformer but may mount differently so mount it in your old can.
I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 10:50 AM
RE: I.F. Transformer rewind help. - by KCMike - 08-26-2016, 12:31 PM
RE: I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 12:53 PM
RE: I.F. Transformer rewind help. - by Radioroslyn - 08-26-2016, 04:39 PM
RE: I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 08:03 PM
RE: I.F. Transformer rewind help. - by GarySP - 08-26-2016, 03:36 PM
RE: I.F. Transformer rewind help. - by GarySP - 08-27-2016, 12:52 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5081 online users. [Complete List]
» 2 Member(s) | 5079 Guest(s)
