I.F. Transformer rewind help.
Thanks for the correction, Terry.  Probably should have mentioned would have to account for layers of windings as well.  Take care, Gary
I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 10:50 AM
RE: I.F. Transformer rewind help. - by KCMike - 08-26-2016, 12:31 PM
RE: I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 12:53 PM
RE: I.F. Transformer rewind help. - by Greenhorn - 08-26-2016, 08:03 PM
RE: I.F. Transformer rewind help. - by GarySP - 08-26-2016, 03:36 PM
RE: I.F. Transformer rewind help. - by GarySP - 08-27-2016, 12:52 PM
There are currently 3405 online users. [Complete List]
» 2 Member(s) | 3403 Guest(s)
