Philco 46-350 Dead
Update...
Talked w/ Dale on the phone to find that he have a bad connection in the filament circuit. With the filaments not conducting there is no load on the HV supply that's why the HV  was too high.
After cleaning up the tube sockets it was sort of working. It also had a very leaky .004 coupling cap at the audio output tube's control grid. After replacement it working much better.
Philco 46-350 Dead - by radiodale - 08-26-2016, 09:18 AM
RE: Philco 46-350 Dead - by Radioroslyn - 08-26-2016, 10:40 AM
RE: Philco 46-350 Dead - by radiodale - 08-26-2016, 11:53 AM
RE: Philco 46-350 Dead - by Radioroslyn - 08-27-2016, 05:47 PM
Restoring Philco 96
There are currently 5285 online users. [Complete List]
» 4 Member(s) | 5281 Guest(s)
AvatarAvatarAvatarAvatar
