Model 16 / Model 500
Looks like you have this one.
http://www.philcoradio.com/gallery/1935b.htm#a
I think yours is a four band based on the 4 dial lights I see in the chassis.
The code # looks like 123.
Congrats on your find it should be a good player.
Model 16 / Model 500 - by NostalgiaRadioTime - 08-28-2016, 10:42 PM
RE: Model 16 / Model 500 - by KCMike - 08-29-2016, 02:33 AM
RE: Model 16 / Model 500 - by KCMike - 08-29-2016, 02:47 AM
RE: Model 16 / Model 500 - by Ron Ramirez - 08-29-2016, 06:06 AM
RE: Model 16 / Model 500 - by NostalgiaRadioTime - 08-29-2016, 07:04 AM
RE: Model 16 / Model 500 - by NostalgiaRadioTime - 09-04-2016, 08:58 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
