Model 16 / Model 500
It's a Model 16 Code 125 (4-band).
16 Code 121 - 5-band, 80 rectifier, in cathedral and the first Deco tombstone cabinet
16 Code 122 - 5-band, console versions, 5Z3 rectifier
16 Code 123 - 5-band, 5Z3 rectifier, chairside model, upside-down dial scale
16 Code 125 - 4-band, 80 rectifier, tombstones (both Deco and flat-top)
16 Code 126 - 4-band, 5Z3 rectifier, console versions
16 Code 127 - 4-band, 5Z3 rectifier, chairside model, upside-down dial scale
500 (1933-34) - 16 Code 122 chassis, manual record player
500X (1935) - Early production uses 16-122 chassis, later models 16-126 chassis; manual record player
501X (1935) - Early production uses 16-122 chassis, later models 16-126 chassis; automatic record player, same cabinet as 1935 500X
Model 16 / Model 500 - by NostalgiaRadioTime - 08-28-2016, 10:42 PM
RE: Model 16 / Model 500 - by KCMike - 08-29-2016, 02:33 AM
RE: Model 16 / Model 500 - by KCMike - 08-29-2016, 02:47 AM
RE: Model 16 / Model 500 - by Ron Ramirez - 08-29-2016, 06:06 AM
RE: Model 16 / Model 500 - by NostalgiaRadioTime - 08-29-2016, 07:04 AM
RE: Model 16 / Model 500 - by NostalgiaRadioTime - 09-04-2016, 08:58 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6389 online users. [Complete List]
» 1 Member(s) | 6388 Guest(s)
