AC/Tone Control Switch for 37-620
I'm repairing a Philco 37-620 with a missing combined AC/tone control switch. I would like to know if the Philco 37-620 uses the same AC/tone control switch as the Philco 37-630. Does anyone have a schematic and parts list for the 37-630? (I couldn't locate a free one on the web.) My 37-620 uses a three-position switch, Part Number 42-1182.
Allen
AC/Tone Control Switch for 37-620 - by Allen in SB - 08-14-2009, 07:14 PM
RE: AC/Tone Control Switch for 37-620 - by ozzyrock2 - 03-26-2013, 08:52 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
