Philco 90 schematic needed
I believe the speaker info is in the speakers zip file here:
http://philcoradio.com/phorum/showthread.php?tid=215
My phone doesn't unzip files so I can't check at the moment.
Philco 90 schematic needed - by Chuck Braun - 08-29-2016, 09:55 AM
RE: Philco 90 schematic needed - by KCMike - 08-29-2016, 11:15 AM
RE: Philco 90 schematic needed - by klondike98 - 08-29-2016, 12:41 PM
RE: Philco 90 schematic needed - by Radioroslyn - 08-29-2016, 11:03 PM
RE: Philco 90 schematic needed - by Chuck Braun - 09-21-2016, 08:29 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6830 online users. [Complete List]
» 3 Member(s) | 6827 Guest(s)
